Every email comes in twice
  • 5 replies
  • 2 views
  • Last reply by LeAnn
Every email comes in twice.. I get 2 of every email
All Replies (5)
have an anti virus scanning incoming email? Disable that function and try again to see if the duplication stops.
every email I send, get sent twice??? outgoing messages are not being scanned.
Modified by LeAnn
I never saw an answer. this has NOT been resolved.
abbarker78645 re: I never saw an answer. Matt reponded and asked you to perform a test and report back with results, but you have not reponded to that request, so we do not know if there is any program interupting the download.
Please could you do the following: Start computer in 'Safe Mode with Networking' Start Thunderbird. Q: Do you still receive two sets?
Are you using a Pop or Imap mail account?
LeAnn re: every email I send, get sent twice??? This question is about receiving duplicates not sending. Are you receiving duplicates as per question? If no, it would be better if you create your own question for the different issue. If yes, please perform the same test.
thanks, will do. New to all this
